Product(s): | InRoads, MX, GEOPAK |
Version(s): | 08.11.09+ |
Area: | General Geometry |
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
How do you insert a PI into horizontal/vertical geometry in OpenRoads?
Answer:
Use the Insert Vertex command located within the MicroStation Modify toolset.
