| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Integration - AutoCAD | ||
| Subarea: | Enable / Disable integration | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
Customization file load failed, file not found: regen
click okay and it gives a message that lists the projectwise\bin\autocad\idoma~1.dll
User is trying to get Projectwise integration to work with AutoCAD
when the user opens a dwg from ProjectWise, the file opens but then he gets the error.
We found that the user had installed the Projectwise Autocad integration module for Autocad 2012
He then upgraded Projectwise to a version that supports AutoCAD 2012
This was causing a conflict
Projectwise in an Integrated World
