The table below is a list of the AutoCAD commands that are integrated with ProjectWise. These commands are supported on all versions of AutoCAD where the command is recognized.
Integrated Command |
Command Description |
Version Introduced |
DMSNEW |
Creates new document |
Pre-XM |
DMSOPEN |
Opens document from ProjectWise |
Pre-XM |
DMSQSAVE, DMSSAVE |
Saves current document |
Pre-XM |
DMSSAVEAS |
Saves current document as new document |
Pre-XM |
DMSQUIT |
Closes AutoCAD and all opened documents |
Pre-XM |
DMSINSERT |
Inserts block from ProjectWise into a drawing |
Pre-XM |
DMSWBLOCK |
Saves block to file in ProjectWise |
Pre-XM |
DMSEXPORT |
Exports document to DMS |
Pre-XM |
DMSFILEOPEN |
Opens document from ProjectWise by ODMA ID |
Pre-XM |
DMSXREF |
Inserts external reference |
Pre-XM |
REFEDIT |
Edits attached external references and blocks |
8.9.3 |
XOPEN |
Opens the selected external reference for editing (Checked out of PW) |
8.9.3 |
PLOT |
Plot active file directly into ProjectWise |
8.9.3 |
DMSPROPERTIES |
Shows dialog with DMS properties |
Pre-XM |
DMSIMAGE |
Inserts image to drawing |
Pre-XM |
DMSOFF |
Disables ProjectWise integration |
Pre-XM |
DMSON |
Enables ProjectWise integration |
Pre-XM |
DMSTB |
Initializes titleblock support |
Pre-XM |
DMSINIT |
Initializes ProjectWise integration (generally is executed automatically) |
Pre-XM |
DMSREFRELOAD |
Reloads references that are out of date |
Pre-XM |
DMSREFCHECK |
Checks to see if references are out of date and prompts to reload them |
Pre-XM |
DMSSET, DMSSETVAR |
Sets a ProjectWise integration variable |
Pre-XM |
DMSFILEINIT |
Initializes integration from a file which is opened by another application |
Pre-XM |
DMSPROFILESET |
Sets AutoCAD profile |
8.9.2 |
DMSINSERTREADLINE |
Inserts redline document |
Pre-XM |
TBUPDATE |
Updates titleblocks in drawing with the data in ProjectWise |
Pre-XM |
TBUPDATEDMS |
Updates data in ProjectWise with the content of the titleblocks in drawing |
Pre-XM |
TBINSERT |
Inserts titleblock in the drawing |
Pre-XM |
TBUPDATEONOPEN |
Performs titleblock update on document open |
Pre-XM |
TBAUTOUPDATE |
Updates titleblocks in the drawing, based on titleblock data in ProjectWise (used by the Attribute Bulk Update tool) |
Pre-XM |
TBAUTOUPDATEDMS |
Updates data in ProjectWise with the content of the titleblocks in the drawing (used by the Attribute Bulk Update tool) |
Pre-XM |
OPENSHEETSET |
Allows to open sheet set from ProjectWise |
8.11.5 |
NEWSHEETSET |
Allows to create new sheet set from ProjectWise |
8.11.5 |
IMAGEATTACH |
Allows to attach image from ProjectWise |
8.9.4 |
DWFATTACH |
Allows to attach DWF from ProjectWise |
8.9.4 |
DGNATTACH |
Allows to attach DGN from ProjectWise |
8.9.4 |
DMSSESSIONFILEMANAGER or SFM |
Displays Session File Manager dialog |
8.11.5 |
DMSPLACEONSHEET |
Executes 'Place on sheet' Sheet Set Manager command |
8.11.5 |
DMSIMPORT |
Performs integrated AutoCAD import operation |
8.9.4 |
DMSREFATTACH |
Registers attached reference on the ProjectWise Integration server Use if the attached reference document exists in ProjectWise but was attached in a non-integrated manner |
8.9.4 |
DATALINK |
Attaches a datalink from ProjectWise |
8.11.5 |
DATALINKUPDATE |
Updates an attached datalink Integration of this command works only when the datalink is reloaded from ProjectWise |
8.11.5 |
ProjectWise TechNotes And FAQs
