User is trying to get Projectwise integration to work with AutoCAD 2012 but when the user opens a dwg from ProjectWise, the referenced files are not found also attributes from title block are not loaded
1. Right click over AutoCAD file in ProjectWise Explorer and select “Open with”,
with option “AutoCAD AutoCAD.DRAWING.PW (C:\Program Files\AutoCAD200*\acad.exe).
Note: * year of AutoCAD version installed in your computer
If this did not resolve the issue move to the next point:
2. Use Scan references and link set options to perform a scan for master and referenced documents.
