| Product(s): | OpenRoads Designer, InRoads, MX, GEOPAK |
| Version(s): | 10.00.00.120+, 08.11.09+ |
| Area: | General Geometry |
Question:
How you can remove a snap constraint?
Answer:
To remove a snap constraint, the geometry needs to be moved in some way. For example, an intersection snap could be overruled by defining a new length constraint that pushes past the snap.
