Product License Filenames
SELECTserver Licensing Landing Page
Document Information
Document Type: TechNote
Product(s):  Geospatial
Version(s):  V7 and V8 prior to XM Edition
Legacy Document Number: 8174
This document lists the license filenames of V8.0 and below Bentley products. The license for SELECTserver License Manager should be in the ...\selectserver directory on the server and should be named license.lic.
For license file names for Bentley Products V8.1 and above, see TechNote 8271.
Files listed in the "SELECTserver License Name" column should contain the line SERVER="server name" (where "server name" is the name of the server running SELECTserver License Manager).
Product Nodelocked License Name Default License Directory SELECTserver License Name
Foundation Products
MicroStation V8 msv8.lic ...\program files\bentley\program\licensing\ msv8.lic
MicroStation/J msj.lic ...\bentley\program\licensing\ msj.lic
Bentley Redline bentleyrdl.lic ...\program files\bentley\program\licensing\ bentleyrdl.lic
Any Engineering Configuration
  MicroStation CivilPAK
  MicroStation GeoGraphics v7.1
  MicroStation Modeler v7.1
  MicroStation Schematics v7.1
  MicroStation TriForma v7.1
MicroStation PowerDraft v8 draftv8.lic ...\bentley\program\licensing\ draftv8.lic
MicroStation PowerDraft v7.1 draft70.lic ...\bentley\program\licensing\ Not Supported
MicroStation PowerScope v7.1 scope70.lic ...\bentley\program\licensing\ Not Supported
Project Review, an EEM Access client prjreview70.lic ...\bentley\program\licensing\ prjreview70.lic
ProjectWise
ProjectWise Document Publisher pwdp.lic ..\program files\allaire\jrun\servlets Not Supported
ProjectWise MarkUpManager License (See TechNote 8339) pwmkp.lic ..\program files\bentley\pwserver\license Not Supported
ProjectWise Server License pw.lic ..\program files\bentley\pwserver\license Not Supported
Viecon
Viecon.interchange interchange.lic ...\bentley\program\licensing\ interchange.lic
Viecon Publisher n/a ..\bentley\program\VieconPublisher vp.lic (must use SELECTserver v7.3)
Imaging and Conversion
Bentley Descartes v8.0 dcartes.lic ...\bentley\program\licensing\ dcartes.lic
MicroStation Descartes v7.0 dcartes.lic ...\bentley\program\licensing\ Not Supported
MicroStation Descartes v7.1 (or higher) dcartes.lic ...\bentley\program\licensing\ dcartes.lic
Bentley I/RAS B v8.0 irasb.lic ...\bentley\program\licensing\ irasb.lic
MicroStation I/RAS B irasb.lic ...\bentley\program\licensing\ irasb.lic
MicroStation ReproGraphics v7.0 repro.lic ...\bentley\program\licensing\ Not Supported
MicroStation ReproGraphics v7.1 repro.lic ...\bentley\program\licensing\ repro.lic
Geoengineering Products
Bentley Water bw.lic ...\bentley\program\licensing\ bw.lic
Bentley WasteWater bww.lic ...\bentley\program\licensing\ bww.lic
Bentley PowerMap powermap.lic ...\bentley\program\licensing\ powermap.lic
GeoSELECTools geoseltools.lic ...\bentley\program\licensing\ msj.lic
GeoXpressions geoxpressions.lic ...\bentley\program\licensing\ geoexpressions.lic
MicroStation GeoCoordinator gcoord.lic ...\bentley\program\licensing\ msj.lic
MicroStation GeoDynSeg dynseg.lic ...\bentley\program\licensing\ dynseg.lic
MicroStation GeoAddress msga.lic ...\bentley\program\licensing\ msga.lic
MicroStation GeoExchange msj.lic (v7.1)
geoexch.lic (v7.0)
MicroStation GeoGraphics msgeo.lic ...\bentley\program\licensing\ msj.lic (uses an EC license)
MicroStation GeoOutlook v7.1 geoolk70.lic  ...\bentley\program\licensing\ Not Supported
MicroStation GeoParcel msgp.lic ...\bentley\program\licensing\ msj.lic
MicroStation GeoTerrain geopakgt.lic ...\bentley\program\licensing\ Not Supported
MicroStation GeoWasteWater msgeoww.lic ...\bentley\program\licensing\ msj.lic
MicroStation GeoWater msgeow.lic ...\bentley\program\licensing\ msj.lic
MicroStation Telco msutelco.lic ...\bentley\program\licensing\ Not Supported
Building & Plant Engineering Products
Architecture for MicroStation TriForma architecture.lic ...\bentley\program\licensing\ msj.lic
Electrical Elementary Diagrams eed.lic ...\bentley\program\licensing\ eed.lic
Equipment Modeler tfeqmod.lic ...\bentley\program\licensing\ tfeqmod.lic
HVAC for MicroStation TriForma hvac.lic ...\bentley\program\licensing\ msj.lic
Interference Manager Ifmeng.lic ...\bentley\program\licensing\ Ifmeng.lic
IsoExtractor isoextps.lic ...\bentley\program\licensing\ isoextps.lic
L/ISO liso.lic ...\bentley\program\licensing\ liso.lic
MicroStation Landscape msla.lic ...\bentley\program\licensing\ msla.lic
MicroStation TriForma v7 triforma.lic ...\bentley\program\licensing\ msj.lic (uses an EC license)
Personal ISOGEN pisogen.lic ...\bentley\program\licensing\ pisogen.lic
PlantSpace Instrumentation psinst.lic ...\bentley\program\licensing\ psinst.lic
PlantSpace P&ID msj.lic
[Note: The future v7.1.4 release will use pspid.lic]
...\bentley\program\licensing\ msj.lic (cut and paste P&ID license info into msj.lic)
PlantSpace Piping 2004 Edition & Bentley PlantSpace AutoIsogen bentleypiping.lic ...\bentley\program\licensing\ bentleypiping.lic
PlantSpace Piping Module pspiping.lic ...\bentley\program\licensing\ pspiping.lic
PlantSpace Piping Module (DIN) pspipingdin.lic ...\bentley\program\licensing\ pspipingdin.lic
PlantSpace SupportModeler pssupmod.lic ...\bentley\program\licensing\ pssupmod.lic
PowerArchitect pwrarch.lic ...\bentley\program\licensing\ msj.lic
Raceways tfrace.lic ...\bentley\program\licensing\ tfrace.lic
Bentley Structural structural.lic ...\bentley\program\licensing\ structural.lic
Structural for MicroStation TriForma stf.lic ...\bentley\program\licensing\ stf.lic
SupportModeler for PDS pssupmodpds.lic ...\bentley\program\licensing\ pssupmodpds.lic
AutoPLANT Products
2D Piping 2.01, 3.0, 8.5 2dpiping.lic ...\program files\bentley\program\licensing\ 2dpiping.lic
AutoISOGEN PLUS 2.01, 3.0, 8.5 autoisogenpl.lic ...\program files\bentley\program\licensing\ Not supported on SELECTserver
AutoPLANT Raceways 8.5 3delect.lic ...\program files\bentley\program\licensing\ 3delect.lic
AutoPLANT Navigator 16.00 plvision.lic ...\program files\bentley\program\licensing\ Not supported on SELECTserver
AutoPIPE Plus 6.3 autopipepl.lic ...\program files\bentley\program\licensing\ autopipepl.lic
AutoPIPE 6.3 autopipe.lic ...\bentley\program\licensing\ autopipe.lic
AutoPIPE Standard 6.2 Not Supported ***** Not Supported
AutoPIPE KHK2 6.3 autopipekhk2.lic ...\bentley\program\licensing\ autopipekhk2.lic
Data Manager 16.0, 8.1 datamanager.lic ...\program files\bentley\program\licensing\ datamanager.lic
Datasheets 16.00, 8.1 datasheets.lic ...\program files\bentley\program\licensing\ datasheets.lic
Drawing Flattener 3.0, 8.5 drawingflattener.lic ...\program files\bentley\program\licensing\ drawingflattener.lic
Electrical 3.0 3delect.lic ...\program files\bentley\program\licensing\ 3delect.lic
Equipment 1.51, 2.00, 2.01 apequipment.lic ...\program files\bentley\program\licensing\ apequipment.lic
Equipment 3.0, 8.5 equipment.lic ...\program files\bentley\program\licensing\ equipment.lic
Explorer 6.2, 7.3, 8.5 apexplorer.lic ...\program files\bentley\program\licensing\ apexplorer.lic
Hookups 16.0, 8.1 hookups.lic ...\program files\bentley\program\licensing\ hookups.lic
Instrumentation 16.0, 8.1 instrumentation.lic ...\program files\bentley\program\licensing\ instrumentation.lic
Interference Detection 6.1, 6.2, 7.3, 8.5 interference.lic ...\program files\bentley\program\licensing\ interference.lic
ISOGEN Server 2.0, 3.0 Not supported ***** Not Supported on SELECTserver
Isometrics 1.51, 2.00, 2.01, 3.0, 8.5 isometrics.lic ...\program files\bentley\program\licensing\ isometrics.lic
Multi-Steel 2D 15.00 multi2d.lic ...\program files\bentley\program\licensing\ multi2d.lic
Multi-Steel 3D 15.00 multi3d.lic ...\program files\bentley\program\licensing\ multi3d.lic
Multi-Steel Modeler 15.00 multimod.lic ...\program files\bentley\program\licensing multimod.lic
NWD Export NWDexport.lic ...\program files\bentley\program\licensing NWDexport.lic
Photorealism Photorealism.lic ...\program files\bentley\program\licensing Photorealism.lic
Piping 1.51, 2.00, 2.01 appiping.lic ...\program files\bentley\program\licensing\ appiping.lic
Piping 3.0, 8.5 piping.lic ...\program files\bentley\program\licensing\ piping.lic
P&ID 16.0 appid.lic ...\program files\bentley\program\licensing\ appid.lic
P&ID 8.1 pid.lic ...\program files\bentley\program\licensing\ pid.lic
P&ID Conversion Toolkit 16.00 pidconvert.lic ...\program files\bentley\program\licensing\ pidconvert.lic
P&ID Converter 8.1 pidconvert.lic ...\program files\bentley\program\licensing\ pidconvert.lic
AutoPLANT Navigator 16.0 plvision.lic ...\program files\bentley\program\licensing\ plvision.lic
PlantFlow 6.0 plantflow.lic ...\program files\bentley\program\licensing\ plantflow.lic
PlantFLOW Plus 6.0 plantflowpl.lic ...\bentley\program\licensing\ plantflowpl.lic
Project Server 3.0 projserv.lic ...\program files\bentley\program\licensing\ projserv.lic
Structural Modeler 16.0, 16.2, 8.5 strucmodeler.lic ...\program files\bentley\program\licensing\ strucmodeler.lic
Structural 3D 16.0 strucengineer.lic ...\program files\bentley\program\licensing\ strucengineer.lic
Structural Engineering 16.2, 8.5 strucengineer.lic ...\program files\entley\program\licensing\ strucengineer.lic
Structural 3D w/NC 16.0 strucdetailer.lic ...\program files\entley\program\licensing\ strucdetailer.lic
Structural Detailer 16.2, 8.5 strucdetailer.lic ...\program files\entley\program\licensing\ strucdetailer.lic
Vision Plvision.lic ...\program files\entley\program\licensing\ Plvision.lic
WinNOZL KHK 3.0 winkhk.lic ...\program files\bentley\program\licensing\ winkhk.lic
WinNOZL WRC107 3.0 winn107.lic ...\program files\bentley\program\licensing\ winn107.lic
WinNOZL WRC297 3.0 winn297.lic ...\program files\bentley\program\licensing\ winn297.lic
WinNOZL API650 3.0 winnapi.lic ...\program files\bentley\program\licensing\ winnapi.lic
WinNOZL PD5500 3.0 winpd55.lic ...\program files\bentley\program\licensing\ winpd55.lic
Integration and Simulation products
Dynamic Animator dynanimator.lic ...\bentley\program\licensing\ dynanimator.lic
Enterprise Navigator entnav.lic ...\bentley\program\licensing\ entnav.lic
ModelServer Integrator msint.lic ...\bentley\program\licensing\ msint.lic
Schedule Simulator schsim.lic ...\bentley\program\licensing\ schsim.lic
Civil Products
InRail selectcad.lic ...\bentley\selectcad\licensing\ selectcad.lic
InRoads v8.3 bentleycivil.lic ...\program files\bentley\civil\licensing\ bentleycivil.lic
InRoads v8.2 selectcad.lic ...\bentley\selectcad\licensing\ selectcad.lic
InRoads Bridge selectcad.lic ...\bentley\selectcad\licensing\ selectcad.lic
InRoads Construction selectcad.lic ...\bentley\selectcad\licensing\ selectcad.lic
InRoads Site selectcad.lic ...\bentley\selectcad\licensing\ selectcad.lic
InRoads Storm & Sanitary selectcad.lic ...\bentley\selectcad\licensing\ selectcad.lic
InRoads Survey selectcad.lic ...\bentley\selectcad\licensing\ selectcad.lic
MicroStation CivilPAK geopakcp.lic or msj.lic (with EC) ...\bentley\program\licensing\ msj.lic or msv8.lic (with EC)
GEOPAK Civil Suite geopak.lic ...\bentley\program\licensing\ msv8.lic or geopak.lic & MS node .lic
GEOPAK Site geopak.lic ...\bentley\program\licensing\ msv8.lic or geopak.lic & MS node .lic
GEOPAK Survey geopak.lic ...\bentley\program\licensing\ msv8.lic or geopak.lic & MS node .lic
GEOPAK Bridge geopak.lic ...\bentley\program\licensing\ msv8.lic or geopak.lic & MS node .lic
GEOPAK Rebar geopak.lic ...\bentley\program\licensing\ msv8.lic or geopak.lic & MS node .lic
Plotting Products
InterPlot Client ipcli.lic ...\Program Files\Common Files\InterPlot\Licensing\ ipcli.lic
InterPlot Driver Pack ipdrvpck.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Mid-Volume Driver Pack ipmvdpk.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Professional ippro.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Raster Offline Driver Pack ipoffdrv.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Server ipsrv.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Digital Print Room Workgroup ipdprwg.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
Digital Print Room Enterprise (12 limit) ipdpr12.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
Digital Print Room Enterprise (unlimited) ipdprunl.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
License File Names for Previous Versions
MicroStation SE ustation.lic
MicroStation 95 ms95.lic
MicroStation V5 ms50.lic
MicroStation ERPIntegrator/S mssap.lic
MicroStation ERPScope/S pscsap.lic
MicroStation GeoAddress sdadr.lic
MicroStation GeoOutlook v5.x geooutlk.lic
MicroStation Image Manager for MicroStation SE usim.lic
MicroStation MasterPiece (previous to MicroStation SE) raytrace.lic
MicroStation Modeler (previous to MicroStation/J) modeler.lic
MicroStation Opti SE optise.lic
MicroStation PowerDraft v5.6 msdraft.lic
MicroStation PowerScope v5.5 msview.lic
MicroStation TeamMate teammate.lic
MicroStation TriForma (previous to MicroStation/J) tf55.lic
ModelServer Imager msiserver.lic
ModelServer TeamMate Document Publisher tmhe.lic
ProjectWise MarkUpManager License mkpmgr.lic
ProjectWise Server License mst.lic
Product TechNotes and FAQs
Geospatial Product TechNotes And FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
