2020 AutoCAD Plug-in FAQ
Integration for AutoCAD 202 and AutoCAD Civil 3d 2020 has been released as a plug-in.
We have some frequently asked questions that I will answer in this Wiki Article.
- What version(s) of ProjectWise will the plug-in work with?
ProjectWise Explorer Client CE 10.00.03.262
- I don’t see the plug-in on Bentley Software Downloads
Bentley Software Downloads Search for ACAD 2020 Plug-in
Note: For this link to work, you may need to login. You will need the rights to download assigned from your organization administrator.
- Enter ProjectWise Integration Module for Autodesk AutoCAD 2020 into the Search Field.
- Select ProjectWise Explorer Client | ProjectWise Integration Module for Autodesk AutoCAD 2020
- The download page should open.
NOTE: If the wrong product is displayed in the download page, then select the back button twice and follow the next steps.
Bentley Software Downloads Complex Search for ACAD 2020 Plug-in
- From the Software Downloads
- Set Product line = Project Delivery and Brand = ProjectWise and Hit Apply
- Clear all the filters by selecting the -Select- value at the top of the list:
This sets the value to nothing (null)
Once all the values are set to null, select Apply
- Now you should see ProjectWise Integration Module for Autodesk AutoCAD 2020 (English) – Released
- Go ahead and download, install and Enjoy!
If you cannot see the correct download please open a support request with the ProjectWise team.
Download a PDF of this instruction: 2020 AutoCAD & Civil 3d Integration
