Product(s): | ProjectWise V8i | ||
Version(s): | 08.11.05.37 | ||
Area: | Idesktop integration | ||
Original Author: | Bentley Technical Support Group |
AutoCAD titleblock update DMS attributes fails,(_tbupdatedms Failed to update attribute values)
2009-08-28 14:49:23,542 ERROR [3976] pwise.server - Error 8152 "ODBC ERROR: 22001: [Microsoft][ODBC SQL Server Driver][SQL Server]String or binary data would be truncated." reported at func: dsqlOdbc_execDirect line: 1055
2009-08-28 14:49:23,542 ERROR [3976] pwise.server - Error 3621 "ODBC ERROR: 01000: [Microsoft][ODBC SQL Server Driver][SQL Server]The statement has been terminated." reported at func: dsqlOdbc_execDirect line: 1055
Data in the title block was longer than the attribute it was bound to in PW attribute exchange.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
