HTTP Error 500.21 - Internal Server Error on SELECTserver Administrative Site
SELECTserver Licensing Landing Page
  Product(s): Bentley SELECTServer, IIS 7x
  Version(s): 08.11.00.00 - Present
  Environment:  N/A
  Area:  N/A
  Subarea:  N/A
  Original Author: Claudio Badalamenti, Bentley Technical Support Group
Warning: Making these changes can cause serious, system-wide problems within your environment. Do not make these changes unless you are confident with these steps and understand the impact to your system and other applications running on it.
The following error message indicates that a problem has occurred on the Web server that hosts the Administrative Web site for SELECTserver. When you try to access content on a server that is running Internet Information Services (IIS) 7.0, IIS 7.0 returns a numeric code that indicates the status of the response. The HTTP status code indicates that the server cannot complete the request because the server encountered an error: (HTTP Error 500.21 - Internal server error) Module not recognized. The correct .NET Framwork version may not be specified in the SELECTserver application pool.
Server Error in Application “DEFAULT WEB SITE/BSS”
Handler "PageHandlerFactory-Integrated" has a bad module "ManagedPipelineHandler" in its module list
Make sure that the SELECTserver application pool has the correct ASP.NET Framework version. Go to Control Panel and open the Administrative Tools folder and run Internet Information Services Manager. Expand the Server folder under the Connections pane then select the SELECTServer Application Pool. If the .NET Framework Version shows “No Managed Code”, than that is the problem. Right click on the SELECTServer Application Pool and choose Advanced Settings. From the dropdown menu of the .NET Framework Version column choose the appropriate version of ASP.NET installed. Click OK to save changes.
External Links
Bentley LEARN Server
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article in the "Comments" area below. THANK YOU!
