| Product(s): | ProjectWise V8i | ||
| Version(s): | 08.11.05.37 | ||
| Area: | Connection Svr-PW Gateway | ||
***Please note this is not certified by development.***
Running Gateway services as an unprivileged user
What is the minimum requirement necessary to run ProjectWise Gateway Services?
Instead of setting a Server Administrator user to run ProjectWise Gateway service you could set the following
Full Control to logging folder (default C:\Documents and Settings\All Users\Application Data\Bentley)
Full Control to File Storage locations (no default location)
Full Control over the following reg keys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Perf_dftperfmgr
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Perf_dmskrnlperfmgr
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Perf_dmsperfmgr
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Perf_dsqlperfmgr
