| Product(s): | InRoads |
| Version(s): | 08.11.07+, 08.11.09+ |
| Area: | Basic Settings |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Problem:
Coordinates are not importing correctly due to the use of a comma instead of a period in the Windows Regional Settings.
Solution 1:
You can change the "," to a "." by going to Start>Control Panel>Region and Language. On the Region and Language dialog, select Additional Settings and change the Decimal symbol to ".".
Solution 2:
In the InRoads/PowerCivil/Power InRoads explorer window, go to Tools>Application Add-Ins. Toggle on "Variable Manager Add-In". Click OK.
Go to Tools>Variable Manager and toggle on “File – Ignore regional settings for decimal separator”.
Other Languages Sources
