| Product(s): | InRoads, GEOPAK, MX | ||
| Version(s): | 08.11.09.878+ | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
This report is the RoadwayDesignMillingReport.xsl with the corrected stationing. The delivered report stylesheet included an externalStation value output for the stationing, but this is a metric Stationing. This report is a corrected report to include the internalStation which is the correct raw output for the imperial stationing,
Unzip the file communities.bentley.com/.../RoadwayDesignMillingReport_5F00_Imperial.zip and place it in the XML Data directory for the correct report path (C:\ProgramData\Bentley\Civil\ReportBrowser\8.11.9\en\Milling) or in a custom folder.
If you are primarily in Imperial Units, it would be recommended to right-click on this report in the XML Report Browser and set it to the Default by selecting 'Set as Default Roadway Design Milling'.
