SELECTserver XM Database Backup [TN]
SELECTserver Licensing Landing Page
  Product(s): SELECT Server XM Edition
  Version(s): All
  Environment:  N/A
  Area:  N/A
  Subarea:  N/A
 How to backup a database
It is good practice to have a backup of critical data such as that contained within your SELECT Server database. This article details how to create such a backup.
In order to backup of a MSSQL or MSDE database you will need to make use of the osql tool. Open a command prompt and type the following, replacing what is in red with the applicable information:
osql -S MyServerName -U user -P password -Q "BACKUP DATABASE [Database Name] TO DISK = N'Path and File Name' WITH NOFORMAT, INIT, NAME = N'[Full Backup]', SKIP, NOREWIND, NOUNLOAD, STATS = 10"
Example:
osql -S DOEHM27519EXT -U sa -P sa -Q "BACKUP DATABASE [SELECTServer] TO DISK = N'c:\SSXM_DB_BACKUP.bak' WITH NOFORMAT, INIT, NAME = N'[Full Backup]', SKIP, NOREWIND, NOUNLOAD, STATS = 10"
This example will generate a database backup named SSXM_DB_BACKUP.bak, located in the c:\ directory.
Product TechNotes and FAQs
Licensing TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
