After upgrading ProjectWise Explorer to SS3 from SS1, office integration with excel and office is showing a blank document.
Registry key comes in play that does not allow the class name to function correctly causing the blank document and not allowing the actual file that is copied out or checked out to open.
After the blank sheet in Excel or blank document in Word opens. Navigate to File open, if dialog in to ProjectWise opens then go to Option 3. If dialog to local client opens then go to option 2
Navigate to the client machines Control Panel and open Program and Features, then click on Uninstall a program. Scroll to 'ProjectWise Explorer V8i (SELECTseries 3)' right click and select change.
In the ProjectWise Explorer V8i (SELECTseries 3) - Setup Wizard, click next, select modify and next, left click idesktop Inetgration and select 'This feature will not be avaliable' click on next, then install
In SELECTseries 3 there was a add on for Office 2010 x86; In control panel scroll down to the ProjectWise office add-on and do the same steps as above: Setup Wizard, click next, left click idesktop Inetgration and select 'This feature will not be avaliable' click on next, then install.
Enable the idesktop integration under the ProjectWise Explorer V8i (SELECTseries 3) - Setup Wizard
Enable the idesktop inegration under the ProjectWise Explorer V8i (SELECTseries 3) Office add-on
The integration now should be enabled and allow you to see in to ProjectWise via Office applications; If there is still a blank document or sheet follow the next steps.
HKEY.CLASSES.ROOT.\Word.Document.PW
HKEY.CLASSES.ROOT.\Excel.Sheet.PW
HKEY.CLASSES.ROOT.\MsProject.Project.PW
