| Product(s): | MXRoad V8i |
| Version(s): | 08.11.09+ |
| Area: | MOSS OLE |
| Original Author | Purva Lakde, Product Advantage Group |
Question:
How to fix MOSS OLE error whenever it generates or when click the browse button to select style set ?
Answer:
To fix this issue in windows Start type Administrative Tools, then select Services. Scroll down to “Touch Keyboard and Handwriting Panel Service” right mouse click and select properties. On the General tab select Stop. Change Startup type from Automatic to Disabled.
