50002 |
Cannot start application for the specified document. Check your program associations. Invalid parameter passed to API function. |
112173 |
Cannot start application for the specified document. Check your program associations. A client's attempt to establish a conversation failed. |
ProjectWise is attempting to open the document in an integrated session, however something is broken with the integration
Right click-unassociate any open actions for the application having the issue. This will default to the appropriate global association (Word.Document.PW or Excel.Document.PW)
NOTE: It is highly recommended to use this method as a last resort since disabling “ALL” add-ins can have adverse affects on application stability and security. Please check with your system administrator or IT department for proper direction first
ex: HKEY_CURRENT_USER\Software\Microsoft\Office\14.0\Word\Resiliency\DisabledItem
2. First identify each addin by interactively examining each key name. e.g. "432189BE". By double-clicking the item you should see a readable path to the location of each add-in. Carefully note the registry key name of each
ProjectWise add-in for removal.
3. Manually verifying, backing up, and deleting the ProjectWise add-in key found in step 2
