SELECTserver Licensing Landing Page
| Product(s): | SELECTserver | ||
| Version(s): | 09.00.00.113 | ||
| Environment: | Window Server 2008 64 bit, Windows 7 32 bit, Windows 7 64 bit, Windows Server 2008 R2 | ||
| Area: | Installation / Configuration | ||
| Subarea: | IIS Configuration | ||
| Original Author: | james white, Bentley Technical Support Group | ||
Create a Virtual Directory (IIS 7)
Applies To: Windows 7,
Windows Server 2008, Windows Server 2008 R2, Windows Vista
A virtual directory is a directory name, used in an address, which corresponds to a physical directory
on the server. You can add a virtual directory that will include directory content in a site or an application without having to move the content physically into that site or application directory.
Prerequisites
For information about the levels at which you can perform this procedure, and the modules, handlers,
and permissions that are required to perform this procedure, see Virtual Directories Feature Requirements (IIS 7).
Exceptions to feature requirements
To add a virtual directory
You can perform this procedure by using the user interface (UI), by running Appcmd.exe commands in a
command-line window, by editing configuration files directly, or by writing WMI scripts.
User Interface
To use the UI
How to create a new Web Site in IIS7
http://communities.bentley.com/products/licensing/w/licensing__wiki/how-to-create-a-new-website-in-iis7.aspx
http://technet.microsoft.com/en-us/library/cc731205(WS.10).aspx
