Enabling Diagnostic Logging for SELECTserver
SELECTserver Licensing Landing Page
  Product(s): SELECTserver
  Version(s): All Versions
  Environment:  N/A
  Area:  Administration
  Subarea:  N/A
  Original Author: Michael Dougherty, Bentley Technical Support Group
1) For versions 09.XX.XX.XX and newer complete the following steps
  1. From a command prompt do the following:
    Type:   CD C:\Program Files\Bentley\SELECTServer and press ENTER
    Type:   ChangeLogLevels.exe -level TRACE and press ENTER
    Type:    IISRESET and press ENTER
  2. Restart the Bentley SELECTserver service.
    Restart the Bentley SELECTserver Gateway service if installed.
  3. Reproduce the error.
  4. Zip up C:\Program Files\Bentley\SELECTServer\LOGS and send it to support.
  5. For information on how to upload your Log File Click Here
  6. To turn the logging back to normal levels, from a command prompt do the following:
    Type:   ChangeLogLevels.exe -level INFO and press ENTER
2) For all versions 08.XX.XX.XX versions
    Type:   ChangeLogLevels.exe /level:TRACE and press ENTER
    Type:   ChangeLogLevels.exe /level:INFO and press ENTER
Product TechNotes and FAQs
External Links
Bentley LEARN Server
