| Product(s): | ProjectWise Client V8i | ||
| Version(s): | 08.11.09.091 | ||
| Area: | Explorer | ||
Updating a number of documents in ProjectWise Explorer with a new version.
Open ProjectWise Administrator, select a user and set the user settings for document creating conflicts. You would want to have the default action be to create a new version.
You may also want to use the settings “apply common rules for entire document selection” and “do not show select an action dialog”. Also, you can set the default version rules to preset how you want them to be numbered (i.e., decimals) and then the “do not show define version rules dialog”. That will prevent the user from having to select anything during the drag and drop process.
