SELECTserver Licensing Landing Page
| Product(s): | SELECTserver Gateway | ||
| Version(s): | N\A | ||
| Area: | License Management | ||
| Subarea: | N\A | ||
| Original Author: | Artur Goldsweer, Bentley Technical Support Group | ||
SELECTserver Gateway service causes 100% CPU usage.
Server maintenance caused blocking of the port 3998. The Gateway was listening to port 3998 when maintenance was being run. After rebooting the machine the problem could not be reproduced.
