| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Integration / Caching /Gateway | ||
| Subarea: | MISC | ||
| Original Author: | Marty Nickel, Bentley Technical Support Group |
User list slow when retrieving information.
The user list retrieves information back from the dms_audt table. When this table is larger it can slowness with the User list displaying in a timely manner.
Apply the attached index. The following is for SQL:
-- This will add an index to the dms_audt table to help with a slow user list
-- Author: Marty Nickel
-- Date Created: 10/3/2012
CREATE NONCLUSTERED INDEX [index_dms_audt_slow_user_list] ON [dbo].[dms_audt]
[o_objtype] ASC,
[o_objno] ASC
INCLUDE ( [o_acttime]) WITH (SORT_IN_TEMPDB = OFF, IGNORE_DUP_KEY = OFF, DROP_EXISTING = OFF, ONLINE = OFF) ON [PRIMARY]
The following is for Oracle:
-- This will add an index to the dms_audt table to help with a slow user list in Oracle
CREATE INDEX aa_custom_audit_1 ON pwise.dms_audt (o_objtype, o_action, o_objno, o_acttime) TABLESPACE PWISE_INDEX
