| Product(s): | InRoads, GEOPAK, MX | ||
| Version(s): | 08.09++ | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
This report is the StationOffsetAlongSingleAlignment.xsl with the point name for on alignment points included in an additional column.
Unzip the following file and place it in the XML Data directory for the version of the product installed. This report may be placed in the Custom folder or the StationOffset folder.
communities.bentley.com/.../StationOffsetAlongSingleAlignmentWPointName.zip
(ex for XM - C:\Program Files\Bentley\InRoads Group V8.9\XML Data\Custom)
(ex for V8i SS2 - C:\Program Files (x86)\Bentley\InRoads Group V8.11\XML Data\en\Custom)
(ex for V8i SS4 - C:\ProgramData\Bentley\Civil\ReportBrowser\8.11.9\en\Clearance)
