| Product(s): | OpenRoads Designer Connect Edition |
| Version(s): | 10.06.00.038 |
| Area: | Feature Migration |
This video demonstrates how to use the GEOPAK DDB Extractor Utility. This stand alone executable will convert a GEOPAK DDB exported to an *.MDB file to three separtate XML files for importing of:
- Element Templates
- Feature Symbologies
- Feature Definitions
to OpenRoads Designer CONNECT Edition.
The utility can be downloaded from the following link
communities.bentley.com/.../3386.civil_5F00_ddb_5F00_utility.zip
Important Information:
1. Make sure the GEOPAK SS2 or SS4 workspace environment you will be exporting the *.DDB to *.MDB file from
has access to all of the following:
- Custom Linestyles
- Levels
- Cells
2. Export the DDB to an *.MDB file
3. Run the executable provided selcting the *.MDB file
4. Select Export to XML to generate the 3 xml files.
5. Make sure this admin config variable is set in your workspace:
_CIVIL_STANDARDS_IMPORTEXPORT = 1
6. Import the Element Templates, then Feature Symbologies, and lastly the Feature Definitions to a new DGNLib.
7. This should only be used with ORD 2018 Release 4 (10.06.00.038) or higher.
KNOWN LIMITATIONS:
- This will NOT "Update" Elememt Templates or Feature symbologies, or Feature Definitions.
If one with the same name already exist, the new imported entry will be given a
suffix of the number 1. Thus, it is best practice to
either delete the entries before import, or import to a new dgnlib file.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
