Last error 58116 Error creating new document. Required fields has no value
Problem:  when user try to drag a file from a local drive (my computer) to any folder of a specific project
“Last error 58116 Error creating new document. Required fields has no value” pops up.
Trouble shooting steps
User was getting the error because he has an environment assigned to the folder , in the environment there are attributes which have required option enabled , while dropping any doc in PW explorer and selecting "no wizard" the error will occur as some attributes were supposed to be updated with the value.
