| Product(s): | InRoads, GEOPAK, MX | ||
| Version(s): | 08.09++ | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
This report is the clearnace.xsl with latitude and longitude of the offset points (cogo points) included in additional columns.
Unzip the following file and place it in the XML Data directory for the version of the product installed. This report may be placed in the Custom folder or the Clearance folder.
communities.bentley.com/.../ClearanceLatLong.zip
(ex for XM - C:\Program Files\Bentley\InRoads Group V8.9\XML Data\Custom)
(ex for V8i SS2 - C:\Program Files (x86)\Bentley\InRoads Group V8.11\XML Data\en\Custom)
(ex for V8i SS4 - C:\ProgramData\Bentley\Civil\ReportBrowser\8.11.9\en\Clearance)
Note: In order to change the Latitude and Longitude Readout, you must edit the Design File Settings > Angle Readout > Format. Once that is change between dd.ddd and DD MM SS, the report will display the different formatting.
