| Product(s): | InRoads | ||
| Version(s): | 08.09.03.06+ | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
This report is Clearance.xsl with only the Point name, Station, and Offset fields populated in the report.
Unzip the file Clearance_NameStationOffset.zip and place it in the XML Data directory for the version of the product installed. This report may be placed in the Custom folder or the Clearance folder.
(ex for XM - C:\Program Files\Bentley\InRoads Group V8.9\XML Data\Custom)
(ex for V8i SS2 - C:\Program Files (x86)\Bentley\InRoads Group V8.11\XML Data\en\Custom)
