Original Author: | Bentley Technical Support Group |
Last Error [116] The server has failed to accept synchronization request. Access is denied.
Troubleshooting looked for errors in pwadmin.log and usersync.log
Usersync.log did not show anything useful except the error message
Pwadmin.log showed 2010-10-11 02:27:49,491 ERROR [0x000008a4] pwise.dms - Error 116 "
Access is denied.
Created a logical user and made sure the user was in the ProjectWise Administrator Group. Also the server name was not correctly setup. We changed the \\servername to server name (removed the \\) typed the username and password for the logical user that was created all worked
