| Product(s): | SELECTserver | ||
| Version(s): | 08.11.07.88 | ||
| Area: | Administration | ||
| Subarea: | Usage Logs Transmittal | ||
| Original Author: | Jeremy Hoesly, Bentley Technical Support Group | ||
When manually transmitting usage logs on a deployed server running SELECTserver 08.11.xx.xx, I am unable to import a response file. The Process File button in Step 4 on the Transmit Usage Logs page is disabled.
The Process File button should function properly when viewing the SELECTserver administration site within Internet Explorer. This workaround does not resolve the problem in alternate browsers such as Google Chrome or Mozilla Firefox.
