| Version(s): | 10.00.00.120+ |
| Area: | Workspace |
How do I control the display of tabs in the Explorer dialog?
The properties of the Explorer dialog can be set from the Explorer Settings dialog (File > Settings > User > Explorer Settings). Within the settings change "visible" option to yes/no as seen in the screen shot below.
