| Version(s): | 10.00.00.120+ |
| Area: | Basic Settings |
| Original Author: | Holly Herring, Bentley Technical Support Group |
How can I customize the keyboard shortcuts to numeric only shortcuts?
Here is an example below:
Once completed, you will be able to use the keyboard to run commands. You must have the Workflow and Ribbon you want selected. In this example my workflow is OpenRoads Modeling and my ribbon is Geometry. When I hit (3) I go into the Horizontal category. When I hit (1) after the (3), I select the Line Between Points command.
