| Version(s): | 10+ |
| Area: | Installation |
Question:
During payload download I get the following error: Failed to copy payload for Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23026
Answer:
- Create a log file
- The file vc_redist.x64.exe is in two different locations and it does not match.
C:\Users\yourusername\Downloads\vc_redist.x64.exe
C:\BentleyDownloads\OpenRoads Designer CONNECT Edition\vc_redist.x64.exe
This usually happens when you have an old download. Remove old downloads. - Delete one of them and also clean out the folder
C:\Users\yourusername\AppData\Local\Temp
