| | Product(s): | ProjectWise Design Integration Server | |
| | Area: | Orchestration Framework | |
| | Subarea: | Full Text Indexing | |
| | Original Author: | Frank Reimann | |
ProjectWise Version 08.11.11.590
Full Text indexing is not indexing Office documents in the newer Office 2010 file format (*.docx, *.xlsx). The older version of Word file format (*.doc) is indexed correctly.
The problem was solved using the following steps:
- Repair Microsoft Filter Pack 2.0
- Restart Indexing Server
