| Product(s): | ProjectWise V8 XM Edition | ||
| Version(s): | 08.09.04.89 | ||
| Area: | Orchestration Framework | ||
What is the role of ustationwrapper.exe in ProjectWise 8.9?
Ustationwrapper.exe creates a clean and unique environment under which ustation.exe will be started. Some of the tasks performed are as follows:
• In order to always have the best path to MicroStation it takes a version range and finds the path to the latest MicroStation within that version range by searching through the registry.
• Creates an environment where multiple MSProcessors can run concurrently. Each MSProcessor has a unique space for reading and writing files that are a natural byproduct of MicroStation processing such as user preference and temporary files.
• Creates an environment where multiple MSProcessors can run headless. All modal dialog boxes are suppressed.
• Redirects MicroStation console log to a unique file
• Services don't have access to mapped network drives. It finds all drives that should be mapped and maps them.
• When the MSProcessor finishes processing a list of key-ins, any files that are locked must get unlocked. This is achieved by switching into a unique empty design file provided by the ustationwrapper.
