Product(s): | ProjectWise Server V8i | ||
Version(s): | 08.11.09.122 | ||
Area: | Index Server | ||
Original Author: | Bentley Technical Support Group |
Full text index in OCR PDF not working
For PDF's full text indexing you will need the ifilter 9.0 installed on the server
For PDF thumbnail and properties you will need Acrobat reader version X installed on server
