| Version(s): | 10.00.00.120+ |
| Area: | Geometry |
Question:
What is the Simplify Geometry tool?
Answer:
Simplify Geometry is a tool used for removal of intervals and external referencing rules for horizontal and vertical geometries.
You can access this tool from Geometry > Common Tools:
This tool should be used with caution, since the referencing rules that constructed the geometry are removed. This means the original design intent no longer exists and the geometry will no longer update since it no longer monitors these elements for changes.
