- User was setting permissions for a folder or project and forgot to give someone full control or at least ability to change permissions. No one can change permissions
- User was setting permissions for a folder or project and forgot to give themselves access to see the folders and now the folders are no longer visible.
- In ProjectWise Administrator, go to users, then find your account or the Administrator account,
- Right click and choose settings, then click on the options tab
- Under 'General' check off the 'use access control' option.
- Click save and close
- Log into ProjectWise Explorer and you should now have full control over the entire datasource.
- Fix the permissions for the folder\files
- Go back to the administrator and check back on the 'use access control' option.
User Properties Dialog > Settings Tab (bentley.com)
