| Product(s): | SELECTserver | ||
| Version(s): | 2014.2.21.3 | ||
| Area: | Administration | ||
| Subarea: | License Management | ||
| Original Author: | Maksim Stankevic, Bentley Technical Support Group | ||
With recent upgrade of SelectServer OnLine the default Maximum Checkout Interval setting changed to 2 days, it was 365 days in the past. This can be configured by a user with Site Administrator rights to a different value, if this parameter is left blank the default value of 2 days applies. To change this setting open the SelectServer Administration Site, http://selectserver.bentley.com/bss and go to Site Configuration->Site Settings.
http://communities.bentley.com/products/licensing/w/default.aspx
