ProjectWise Explorer (all versions)
Last Error [50132] Error creating new document. The file does not exist.
User is trying to copy a file from a camera (that is connected via usb to the computer) into ProjectWise and is getting the following error. Last Error [50132] Error creating new document. The file does not exist.
Open Windows Explorer and click on This PC
Under Devices and Drives you will see your camera or phone.
However this is a Device and not a Drive.
You can tell because it does not give it a drive letter and the icon is not the same as the hard drive.
ProjectWise will not accept files from a device.. only from an actual drive.
Drag the files from the device to the hard drive then from the hard drive to ProjectWise
