Issue uploading documents from Windows to ProjectWise – Last error [50132] Can not create document.
Problem:  Issue with uploading documents from Windows to ProjectWise Explorer due to the following error message: Last Error [50132] Can not create document. The file does not exist.
This issue may occur for one user only.
Troubleshooting steps
 Then, let the user make a test by adding a new document to ProjectWise Explorer Folder.
