ProjectWise Caching/Integration Server
Fetchfiles utility does not recognize folders with spaces in the name (e.g. “Folder with spaces”) when trying to prepopulate the Cache one folder at a time.
The solution is to use the [-i inputfile] option.
Example:
Instead of typing this in the command line:
fetchfiles.exe -d server:datasource -u user -p password -w C:\FetchFileWorkingDir -r \path\to\folder with spaces
Type this:
fetchfiles.exe -d server:datasource -u user -p password -w C:\FetchFileWorkingDir -i \path\to\inputfile
And in the inputfile, which is a simple notepad file, type this:
-u user
-p password
Fetchfiles Options in ProjectWise Administrator Help
