| Product(s): | Open Roads Designer |
| Version(s): | 10.00.00+ |
| Area: | Geometry |
| Original Author: | Purva Lakde. Product Advantage Group |
Question:
Is there any tool in OpenRoads Designer that would copy an alignment parallel to a proposed alignment ?
Answer:
To copy an alignment parallel to a proposed alignment in OpenRoads Designer, will need to use “Single Offset Entire Element” for horizontal alignment and “Profile Offset Transition” for vertical alignment.
