Create advanced Gateway Log file
SELECTserver Licensing Landing Page
  Bezieht sich auf
  Produkt(e): SELECTserver Gateway
  Version(en): N\A
  Umgebung:  N\A
  Produktbereich:  N\A
  Produktunterbereich:  N\A
  Ursprünglicher Autor: Jutta Eisenhauer, Bentley Technical Support Group
To search the cause of a Gateway error an advanced log file must be created and send to the support.
Change following line in file Bentley.SelectServer.Gateway.exe.config
which is default located in
C:\Program Files\Bentley\SELECTServer and can be opened e.g. with an editor
<level value="INFO" /> in <level value="TRACE" />
 Afterwards:
  1. Try to start the Gateway Windows service
  2. Open licence manager
  3. Check Server name and Site activation key by test connection
  4. Send usage logs by Options > Send logs now menu (or short key F9)
  5. Start a product which is licensed by Gateway
Now send file SS-Bentley.SelectServer.Gateway.exe.log and other available log files in folder ...\program files\bentley\Selectserver\logs zipped to Bentley
https://www.bentley.com/en/support
See also
Other Language sources
Deutsch
