For ProjectWise SDK Development and Programming Questions, Search and Ask here: Developer and Programming Forums > ProjectWise Programming Forum.
BENTLEY DEVELOPER NETWORK
To Access and Download the ProjectWise SDK:
Bentley has created ProjectWise Extensions for use with Microsoft PowerShell.
PowerShell Extensions provides the ability to do certain functions inside of ProjectWise through PowerShell Commands.
You can do such things as:
ProjectWise PowerShell Forum
A user using PowerShell Module PWPS_DAB might have queries related to some scripts not working or need some guidance to use.
Bentley Technical support does not support PowerShell through service requests. PowerShell is only supported via the Communities forum for PowerShell.
Please post your PowerShell questions here: ProjectWise PowerShell Extensions Forum
Additional Resources:
PLEASE NOTE: The PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available from the community of users via the BE Communities site."
