| Product(s): | OpenRoads Designer Connect Edition | |
| Version(s): | 10.02.00.60 | |
| Area: | Aqua-Planning | |
| Original Author: | Amita Shinde |
This video demonstrates the steps for Aqua-planning in OpenRoads Designer. This is a new tool that is introduced in ORD. Aqua-planning is essential to avoid skidding of the vehicles on wet roads. This tool generates the report that gives the film depth. A depth of more that 4mm is not suitable and the geometry needs to be redesigned.
