| Product(s): | OpenRoads Designer Connect Edition | |
| Version(s): | 10.00.00.120 | |
| Area: | Terrain Modelling | |
| Original Author: | Amita Shinde |
Following wiki video demonstrates the steps to import a .3mx file into OpenRoads Designer, and create a terrain using the "Ground Extraction" tool. This terrain can then be exported as a LandXML file.
