# Name: WorkSpacePWSetup_Predefined_XXXX_CE.cfg
# Description: Allows organization to augment a client's WorkSpace at the predefined level
# Author: Buddy Branham
# Date: 2022/02/28
# Version: 2.0.0.0
# Notes:
# - This file is included from Common_Predefined.cfg
# - 2021-05-14 Adjusted Dynamic Name logic
# - 2021-06-11 Added Nested WorkArea Capabilities (1.6.0)
# - 2021-08-09 General Upates to match 1.7.0 (1.7.0)
# - 2021-08-18 General Updates to more closely align with V8 version (1.7.1)
# - 2021-08-18 General Updates to more closely align with V8 version.(1.7.1)
# - 2021-02-21 Refactored and reorganized.(2.0.0.0)
# - 2021-02-27 Revise error messages.(2.0.0.0)
# - 2022-02-28 Initial Release (2.0.0.0)
# DYNAMIC CONFIG VARIABLE
# The "_DYNAMIC_CONFIGS" variable can be appended in each cfg file to track
# loading of cfgs and other notations.
_DYNAMIC_CONFIGS > WorkSpacePWSetup_Predefined_XXXX_CE.cfg 2.0.0.0
# COMMON PREDEFINED VERSION MATCH VERIFICATION
%if !defined (_DYNAMIC_COMMONPREDEFINED_PWSETUP_MAJOR) || ((_DYNAMIC_COMMONPREDEFINED_PWSETUP_MAJOR)<8)
 %error Workspace setup needs updated version of Common Predefined files.
%endif
# 1-OPTION: FIND NAME IN PATH
# Parses _DGNDIR path to fine directory name relative to _DYNAMIC_WORKAREAROOT
%if defined (_DYNAMIC_WORKAREAROOT_NAME)
 FINDDIR_SEARCHPATH:$(_DGNDIR) #Path to search, typically _DGNDIR.
 FINDDIR_NAME=$(_DYNAMIC_WORKAREAROOT_NAME) #Searches FINDDIR_SEARCHPATH to find this directory name.
 FINDDIR_NEST=1 #Sets nest level of directory to find up from "found" directory.
 FINDDIR_UNDEF=1 #1, undefines variables to avoid copyout of each directory.
 FINDDIR_FOUND=0 #Flag to identify if path has been previously parsed.
 %include $(_DYNAMIC_DATASOURCE_BENTLEYROOT)FindNameInPath.cfg
_DYNAMIC_NEST1=${FINDDIR_FOUNDNAME}
 _DYNAMIC_NEST1DIR=${FINDDIR_FOUNDDIR}
 %endif
# 2-WORKSETS ROOT
# Set the location for each WorkSet CFG and WorkSet DGNWS
# (see WorkSpacePWSetup_Predefined_Example_Scenarios.txt)
 ##### Define Worksets Root relative to a WORKAREA
 %if defined (_DYNAMIC_WORKAREAROOT)
 ##### EDIT: Match path relative to WorkArea Root
 _DYNAMIC_WORKAREA_CFG_PATH :_PWSetup/WorkSets/
 %if exists ($(_DYNAMIC_WORKAREAROOT)$(_DYNAMIC_WORKAREA_CFG_PATH))
 _DYNAMIC_WORKAREA_CFG_ROOT:$(_DYNAMIC_WORKAREAROOT)$(_DYNAMIC_WORKAREA_CFG_PATH)
 %else
 ##### EDIT: Disable this error message if Worksets Root might not be in WorkArea
 %error $(_DYNAMIC_MSG_NOT_FOUND) _DYNAMIC_WORKAREA_CFG_PATH: $(_DYNAMIC_WORKAREA_CFG_PATH)
 %endif
 %endif
 ##### If Cfg Root not found, set value to locaction in WorkSpace.
 _DYNAMIC_WORKAREA_CFG_ROOT:$(_DYNAMIC_CEWORKSPACEROOT)WorkSets/
 _USTN_WORKSETSROOT: $(_DYNAMIC_WORKAREA_CFG_ROOT)
 %lock _USTN_WORKSETSROOT
# 3-WORKSET CFG
 _DYNAMIC_WORKSET_DEFAULTNAME:CONNECTExample
 %if defined (_DYNAMIC_WORKAREAROOT_NAME) && exists ($(_DYNAMIC_WORKAREA_CFG_ROOT)$(_DYNAMIC_WORKAREAROOT_NAME).cfg)
 _USTN_WORKSETCFG=$(_DYNAMIC_WORKAREA_CFG_ROOT)$(_DYNAMIC_WORKAREAROOT_NAME).cfg
 _USTN_WORKSETNAME=$(_DYNAMIC_WORKAREAROOT_NAME)
 %elif exists ($(_DYNAMIC_WORKAREA_CFG_ROOT)$(_DYNAMIC_WORKSET_DEFAULTNAME).cfg)
 _USTN_WORKSETCFG=$(_DYNAMIC_WORKAREA_CFG_ROOT)$(_DYNAMIC_WORKSET_DEFAULTNAME).cfg
 _USTN_WORKSETNAME=$(_DYNAMIC_WORKSET_DEFAULTNAME)
 %else
 %error $(_DYNAMIC_MSG_NOT_FOUND) WORKSET CFG: $(_DYNAMIC_WORKAREA_CFG_ROOT)$(_DYNAMIC_WORKAREAROOT_NAME).cfg or $(_DYNAMIC_WORKSET_DEFAULTNAME).cfg
 %endif
 %lock _USTN_WORKSETNAME
 %lock _USTN_WORKSETCFG
# 4-WORKSET ROOT
 #_DYNAMIC_WORKAREA_WORKSET_PATH : ContractDrawings/
%if exists ($(_DYNAMIC_WORKAREAROOT)$(_DYNAMIC_WORKAREA_WORKSET_PATH))
 _DYNAMIC_WORKAREA_WORKSET_ROOT:$(_DYNAMIC_WORKAREAROOT)$(_DYNAMIC_WORKAREA_WORKSET_PATH)
 %else
 ##### EDIT: Disable this error message if Workset Root might not be in WorkArea
 %error $(_DYNAMIC_MSG_NOT_FOUND) _DYNAMIC_WORKAREA_WORKSET_PATH: $(_DYNAMIC_WORKAREAROOT)$(_DYNAMIC_WORKAREA_WORKSET_PATH)
 %endif
 %endif
 _DYNAMIC_WORKAREA_WORKSET_ROOT:$(_DYNAMIC_CEWORKSPACEROOT)WorkSets/$(_USTN_WORKSETNAME)/
 _USTN_WORKSETROOT: $(_DYNAMIC_WORKAREA_WORKSET_ROOT)
 %lock _USTN_WORKSETROOT
# 5-WORKSET DGNWS
 _USTN_WORKSETSDGNWSROOT : $(_USTN_WORKSETSROOT)
 #_USTN_WORKSETDGNWS=$(_DYNAMIC_WORKAREA)$(_DYNAMIC_ROLE).dgnws
# 6-OTHER SPECIFIC CONFIGURATIONS
# For the specific WorkSpace, you may need to set some variables here
# to properly load the entire WorkSpace successfully
