Last Error 222 Cannot start application for a specified document. Failed to generate managed workspa
Problem:
All users are unable to open MicroStation files from ProjectWise, getting "Last Error 222. Cannot start application for the specified document. Check your program associations. Failed to generate managed workspace configuration file. File not found on server."
Before the error appeared, there were no software updates/reinstallations. All configurations have been working well to date.
This error normally occurs when there is a problem with a ProjectWise Managed Workspace.  To troubleshoot the issue:
