Product(s): | SELECTserver and SELECTserver Gateway | ||
Version(s): | 09.01.00.26 | ||
Environment: | Windows 7, Windows 8.x, Windows 10, Windows Server 2008, Windows Server 2008 R2, Windows Server 2012, Windows Server 2012 R2, Windows Server 2016 | ||
Area: | Installation / Configuration | ||
Subarea: | Windows Installer Errors |
The following error occurs when attempting to start the SELECTserver or SELECTserver Gateway installer:
This setup requires Microsoft .NET Framework 4.5 Full package or greater to be installed for installation to continue.
SELECTserver components rely upon either Microsoft .NET Framework 4.5 or 4.6, a component that is built into most versions of Windows except Windows 7 and Windows Server 2008.
The following package for Microsoft .NET Framework 4.5.2 from Microsoft's website will satisfy this prerequisite.
Original Author: | Jeremy Hoesly |
