ProjectWise Administrator
ProjectWise Administrator is the primary application used to administer the ProjectWise Integration Server.
ProjectWise Administrator is a Microsoft Management Console Snap-in that can be installed on each desktop so that a user could gain access to administrative functionality.
ProjectWise Administrator requires a ProjectWise Passport.
DMSConv
Environments
ProjectWise Workflow Rules Engine
Miscellaneous:
| Key: | |
| CS – Client Server Article | FAQ – Frequently Asked Questions |
| TB – Technical Bulletin | TN – TechNote |
| VID – SELECTsupport Video |
