| Product(s): | SELECTserver | ||
| Version(s): | N\A | ||
| Area: | Administration | ||
| Subarea: | License Management |
Question:
I have a Deployed License server, and we recently moved away from our contract becoming NON-SELECT.
Now our license server shows the message that the license has expired. How do we import/get a new license?
The use of a Deployed License server is exclusively for our SELECT users.
NON-SELECT users of Bentley software should license their application via the Hosted License server and checkout a license for each workstation/computer.
Steps to this procedure can fe found in the wiki article Activating as a NON-SELECT or Node Locked user.
SELECTserver TechNotes and FAQs
License and SELECTserver Administration [FAQ]
Other Language Sources
| Original Author: | Rene vandenBrink |
